- 210
- 62
- 28
- Carmel IN
Hi All,
I have a 1986 M1009 and have had this problem only twice since I bought it in the last 3 months. The first time I was driving my CUCV and stopped for less than 5 minutes. When I came out and turned the ignition key the glow plugs did their thing like normal. But when I tried to engage the starter there was nothing. No clicking no nothing. Tried a few more times and would not engage the starter. I let it set for about 5 hours then when I tried it again it started just like normal. That was over a month ago in temps around 45. I did check and the battery cables are very tight on both batteries. Yesterday I had the same problem. Turned the key, glow plugs light came on then went off, turned the key and nothing. I moved the transmission shifting lever a little and still nothing, tried the key again before I turned it off still nothing. I then turned the key off and started the same process and again nothing. Then with the key not engaged I just shook the whole truck and tried to start it again. Bam it started. I drove it home. turned it off and started again no problem. Started again this morning just fine.
Wanted to know if anyone has any suggestions. Thanks
