- 3,214
- 377
- 83
- Tonopah, AZ
I picked up a M970 fuel trailer with a Onan 4 cly motor on it. I changed the fuel filters and flashed the lines out, than I tried to start it and I can not get it started. I think it is the same motor that is on the MEP003A.
It turns over but will not fire up. The injectors or not getting fuel so I guess the IP pump is gummed
up with old diesel.
I guess I need some help with taking it off and replacing the ip pump. I am not sure about how to set the timing on this type of motor.
I also noticed the fuel stop solenoid is not pulling back. Does it need to pull back when you hit the starter switch?
Any help would be apprenticed!!
up with old diesel.
