starting problem
juan lopez jr
LaMarque, Texas
hey fellas, I'm new to Steel Soldiers, i Have a 1984 M925 5ton that wont start, I'm getting voltage, but, when i activate engine start switch, i get a sound from behind/under the cab, and nothing at the starter, any help/advice to point me in the right direction would be greatly appreciated
Scrounger
66
Southern, Maryland
There are several things that could be a problem. Whenever this “problem” occurs the first place to check is the Protection Control Box (PCB). It is the large metal box under the hood on the firewall, in front of the driver. It has a couple of connectors with a bunch of wires coming out of the bottom. There are mechanical relays in the PCB that tend to go bad. Take a hammer and hit on the top of the box a few times. Then check and see if the truck will start. It can take more than a couple of tries. If the truck starts, then the box will need to be replaced.
If that doesn’t work, then it is time to break out the test light and multi-meter.
Try hitting the PCB first.
