Starting problems 1991 Humvee
Kenneth Cole
41
Wapiti Wyoming
Hi
When the engine is cold the solenoid will disengage after one or two turns. Once she is warmed up from either the block heater or from been driven she will start right away .
My thought is that the starter solenoid is the problem.
I hope that this is making sense .
Ken
Dieselmeister
264
Flagstaff, Az
Could be low voltage. Check the voltage at the solenoid when this happens. It could be a weak battery or bad connection. When cold starting, and the glowplugs re-energize while cranking, the voltage could go low enough to drop out the solenoid. Do some more testing before replacing anything. Starters are expensive.
Kenneth Cole
41
Wapiti Wyoming
Sir
Thanks for the info. It makes sense. As soon as the weather (snow) gets better I will check it out.
Ken
Bulldogger
647
Quantico VA
Agree w checking all wiring connections and battery state of charge. Could be something simple (not that new batteries are cheap, but you get the idea). Also, not everyone knows that the post the positive lead off the forward battery goes to has a corresponding post on the other side, meaning that wire has to be tight too, even if the post inside the battery box is super tight. It could be loose on the other side. Doesn't sound like your issue, but I like to share that nugget whenever potential low voltage is mentioned and batteries come up.
You'll get it!
Bulldogger
