Starting the m934A2?
Gunny65
Bonners Ferry, idaho
I have power when I turn the battery switch on and the start switch is on run. When I pull up the run/start switch to the start position, nothing. Not even a click. It is in neutral and brake is set and buzzing. It ran for 4 hours, turned it off and immediately tried o start it. I am now stuck. Oh, and stinking tired so I am easily missing something. Thanks.
M35A2-AZ
390
Tonopah, AZ
I would look at the the neutral start switch, black control box, solenoid or wiring.
Try to short the solenoid and see if it turns over.
MtnSnow
14
NSL, UT
Most likely the batteries are unable to provide anything beyond surface voltage. Pull the 4 batteries and install 2 known good fully charged batteries. Then you can try individually charging the old batteries and then have them load tested. My bet is they will fail the load test.
Gunny65
You are all correct. I was so tired I just wasn't thinking. it was totally dead in the morning. We swapped out two batteries and she fired up immediatly. Then I moved this piece of cardboard on the dash and Behold! All kinds of info printed on the dash panel. Thanks for the help though. It is amazing what a little sleep can do.
