STE/ICE diagnostic port, Atlanta area
CycleJay
Marietta, Ga
Hi guys,
Does anyone in the Atlanta area have one of those STE/ICE-R kits?
That you plug into the STE/ICE port on the CUCV to test the
eletrical system?
If so, please let me know. I have a question or two to ask you.
Thank you...
Lieutenant
57
Michigan
Ask away, maybe someone not in the Atlanta area can answer them.
CycleJay
Marietta, Ga
Hi guys,
The reason I mentioned the Atlant area is.
Because I was wondering if anyone in the Atlanta area that has one,
can hook it up to my STE/ICE port, to check for any issues I may not be aware of.
I would be willing to pay them to test it, as long as it did not cost me an arm and a leg,
or my first born (especially since I have no children of my own.)
Warthog
232
OKC, OK
Very few people have a working unit. Even if they do the units really don't tell you much.
They are NOT like the ODB-II units on the new cars.
Keith_J
1,319
Schertz TX
It monitors fuel pressure in the filter housing, engine speed and alternator voltage. Nothing you cannot measure with simple tools.
STE-ICE was a great idea but terrible implementation. It was the least used tool in the shop set, I never heard of it being used.
jdknech
Jeffersonville, Indiana
I may be stepping out on thin ice... but if you could monitor engine speed, does that mean theres a way to hook in a tach?:!:
cpf240
Free in Northern Idaho
The STE/ICE port has a connection to the tach output of GEN1, passed through a tach buffer. There is at least one SS member who was able to find a tach that would run off that signal.
319
Lieutenant
57
Michigan
I'll have to read my manual again but I believe it states in there that a tach adapter is needed for the CUCVs. It's been a couple of years, but I've hooked my STE/ICE-R to my CUCVs and the only reading I could get without connecting adapters and transducers and what not to the engine, was battery voltage.
Mine was virtually "new" when I bought it, actually still is, looked as though it's never been used, and checked in 2004 or 6 or so. Self tests good and I have all of the adapters......except for the elusive CUCV tach adapter which was never part of the kit.
You're better off buying off the shelf automotive test equipment, because it's universal, has a warranty, and can be repaired.
CycleJay
Marietta, Ga
Hi guys,
No big deal, it was just a thought to see what I could find out, if anything.
319: Since you have one of those STE/ICE-R kits, please let me know if
you ever want to sell it.
Thanks guys
319
Lieutenant
57
Michigan
Mine won't be sale for a long long time. It's under lock and key and guarded by an Ex-GL employee driving a fork-lift.
Castle Bravo
Hundredaire Socialite
215
Arizona
When I had mine, I tested my tach reading on my CUCV with just the W-1 cable and the STE/ICE itself. It doesn't need anything else to work, provided you've got your tach wire hooked up on the back of the GEN 1 alternator.
http://www.steelsoldiers.com/deuce/72625-ste-ice.html#post1123244
Skinny
488
Portsmouth, NH
If you have a good multimeter, this diagnostic device is useless. It was stated before, it isn't like an OBDII car. Even older cars pre 95 have computers with serial data that will talk to a scan tool. The CUCV's have nothing. Save your money for a good fluke meter and an infared temp gun. Money better spent...
319
Lieutenant
57
Michigan
