kennys@wi.rr.com
- 23
- 38
- Waukesha, WI
Well I've had my deuce for a little over a month now and I love it. I wasn't sure how much I'd like the built cargo cover but before plotting it's demise I decided to leave it as is for a while. After camping in it for a few nights while at the parade by MikeInMcCoy I realised how much I enjoy having this type of cover. I also like the fact that I can stash all of the tools I can think of needing to work on the deuce in the back, there is a nice flip top work bench in the back.
So here is my list of questions and thoughts and I'd like some input as to what would you do if it was your truck.
The roof does leak a small amount now. Seems that they built the cover from one side over not from the top down. So the seems where the metal overlaps are on top on one side and bottom on the other. Also the caulk on the very top gave out and I think some of the rubber washers on the screws are dryed out. Do I remove the panels and put them back on in the same spot but starting at the top and working my way down both sides or do I just recaulk all the seems and use some kind of a sealer like that used on campers?
Right now the back door is nothing more than a 4X8 sheet of plywood that doesn't close very well. I think I would like to put on a regular steel entry door. Do I use just one 36" door or do I go with a side by side type to keep the door a 48" opening? I'm leaning to the 36" but there may be an issue there I am not aware of. Then do I leave the tailgate on as it is or do I remove it and leave it off?
I am also considering a window type AC unit in the front of it. That will be great for those hot days but what about the cold nights? Is there a window type unit that heats and cools? How do I protect it as I'm driving down the road or will it be fine?
Up until a few minutes ago the inside was covered with a layer of ciling tiles on the curves and the old style fiber sheeting on the flats, then 3 mil plastic and to make it look "pretty" 1/8" hard board. As I mentioned earlier the roof had a leak so all of that had to come out. Now after I fix the leak do I reinsulate it like it was and recover it with hardboard and paint it or is there a better material to cover it all in. No I will not cover it in shag carpet and put a water bed in back and mirrors on the ceilling. Well maybe that's not such a bad idea?
The floor was covered much the same as the walls but they had the plastic down first. So you can imagine the shape of my floor, no holes just real rough. Should I sand blast it and coat it with bed liner? Do I need to sand blast it first? Is there a better option?
Any other ideas would be greatly appreciated also. I will post more pics of the back as I can take them, for now I am going to add some of when I first gott it.
