Steering box failure / cracking
Reworked LMTV
Expedition Campers Limited, LLC
1,169
TN
I note that one of our members had a steering box failure, with a large crack in the body. Any thoughts as to what might cause this? Have others had the same issue?
coachgeo
3,404
North of Cincy OH
if your speaking of Sean Filner on video.... don't think he is a member here... just Facebook. Good fellow. It broke in an experiment with using a hydraulic driven AC compressor. He made some mistakes which result put too much pressure through the steering pump and grenaded it.
He replaced it.... re did things and now steering is back to spec and Hummer Red Dot AC is working. See his video for more info.
yertnamreg
21
Houston TX
Any thoughts on his A/C setup? My concern is that the power steering pump will go next due to the increased load, but I'm not a hydraulics expert.
