Steering Box
mytoyz
Denville/NJ
I just bought a 1991 and need to get a steering box and pitman arm but having difficulty finding any part numbers the ones I can are for 1992 and up and have 4 bolts the one I am missing has 3?
Action
1,555
East Tennessee
I don't have the same box, but I think yours has 4 holes, and only 3 are used.
The same box should be used all the way through serial number 246889.
Where did you get the 1992 from? That would be the beginning of the H1.
mytoyz
Denville/NJ
Thank you I just found it on a manual with it using only 3 bolts and that makes sense it is stamped 6/91 ser 117379 but everything i am looking for starts at 92
appreciate the help
sully199
coral springs Fl
there will be a place in your area that will rebild it for you, any place that rebuilds rack and pinions can do it for you. I do it for my customers truck, run about $200, if you do that ask them to check and make sure there is not and rubber in the steering gear. if there si you know you need to replace your lines.
