Steering Column P-N-D-2-1 cable support?
cucvegas
12
NW Arkansas
Does anyone know of a good way to support the cable that pulls the gear selector on the steering column / dash? The plastic piece that holds the wire broke off.
I tried JB weld to hold the plastic piece that broke off, and it wasn't strong enough.
Could you screw in a small bolt to let the cable run over the smooth shank?
Thanks!
cucvrus
10,316
Jonestown Pennsylvania
Yes. I have done it many times. Get an 1/8" drill bit and drill a hole in the steel dash where the axis center should be on the cable guide. Get a T nut a 1/24 T nut from a hardware store and a sheet metal screw long enough to fit thru the T nut and attach to the steel dash. Grease the T nut and the cable. Adjust on the column shift sleeve and call it fixed. Good Luck. Be Safe.
cucvrus
10,316
Check this out. I did some repairs to this nice M1009 back in December 2019. Shows my T nut and screw and end results. Go thru the thread. I have a few pointers in there. hope they help. Good Luck.
cucvegas
12
NW Arkansas
Thank you!!!
