Steering issues
TacMac2012
141
Wallburg, NC
Anyone ever had steering issues? Not sure if the steering box needs some sort of adjustment, but I have a truck that has a long 'pause' from when you put effort to turn the steering wheel before the power steering kicks in and it actually turns the tires. Once it starts it turns fine (not weak), but if you switch from turning left to right (or right to left), or stop turning then start again it lags every time. Not sure if there is a procedure to bleed the system, I figure it would just self bleed with use. It was drained of fluid when I got it.
Elijah95
Certified Rookie
1,247
1,222
Georgia
Are you using 10wt or 15w40 motor oil?
Elijah95
Certified Rookie
1,247
1,222
Georgia
Awesome. Should be okay, they ran motor oil in them. You’re probably spot on with the air bubbles. If you have a way to jack it up, it lights not hurt to jack it up and steer left to right back and forth from lock to lock slowly to help purge it out. Lot of lines and 2 steering boxes
