TacticalDoc
- 26
- 18
- Otisville MI
I looked up the TM and did a SS search but still have questions.
(1)....apply adhesive to exposed zipper and fabric. Allow adhesive to sitovernight. What adhesive am I supposed to use? Can you use seal maker?
(2) Discard safety wire (1). Where can you find a replacement for the safety wire? Is it just standard wire?
(3) 5. Lace zipper locks with fine wire near edge of steering knuckle seal (13) and twist together.
(4) How do you fill it with grease? How do you know how much grease to put in it?
I'm sure I'll have more questions but just wanted to ask some questions before starting.
a. Removal
1. Remove four screws (4), lockwashers (3), and seal guard (5) from steering knuckle (2). Discard
lockwashers (3).
2. Remove twelve screws (7), safety wire (1), and retaining plate (6) from steering knuckle (2). Discard
safety wire (1).
3. Pull one side of steering knuckle seal (12) aside to expose inner retaining clamp screw (10).
4. Remove inner retaining clamp screw (10) and spacer (9) from inner retaining clamp (11).
5. Remove seal (12) and inner retaining clamp (11) from steering knuckle (2).
NOTE
Some seals may not have a zipper.
6. Open zipper (or cut to remove seal (12) from axle housing (13).
b. Cleaning and Inspection
1. Clean surface of steering knuckle (2), retaining plate (6), and steering knuckle seal (12) with
cleaning cloth. Ensure there is no dirt or dust is inside steering knuckle (2).
2. Inspect steering knuckle seal (12) for cracks, tears, and damaged zipper Replace if cracked, torn,
or zipper is damaged.
c. Installation
1. Place steering knuckle seal (12) on axle housing (13), with fabric side of zipper facing steering
knuckle (2).
2. Close zipper and apply large amount of adhesive to locks and fabric of zipper. Allow adhesive
to sit overnight.
3. Force inner lip of steering knuckle seal (12) into groove on axle housing (13). Ensure steering
knuckle seal (12) is aligned to holes in steering knuckle (2).
4. Position inner retaining clamp (11) to lip of seal (12) and install clamp screw (10) and spacer (9).
6. Cut off excess zipper and apply adhesive to exposed zipper and fabric. Allow adhesive to sit
overnight.
7. Align seal retaining plate (6) to holes in steering knuckle (2) and install twelve screws (7). Ensure
notches in screw (7) heads are aligned so safety wire (1) can be installed.
8. Thread new safety wire (1) around each screw (7) and tie Off.
9. Install seal guard (5) on steering knuckle (2) with four new lockwashers (3) and screws (4). Tighten
screws (4) 130-170 lb-ft (176-231 N.m).
a. Removal
lockwashers (3).
safety wire (1).
NOTE
c. Installation
knuckle (2).
to sit overnight.
overnight.
