Steering knuckle boot
daddy2
Easton, PA
Anyone know who sells the zippered replacement steering knuckle boots. I had the drivers side tear a day or two ago on the M36a2. Just need the replacement boot and some warmer weather.
Capt.Marion
15
Atlanta, GA
EVERYBODY! Saturn Surplus, OD Iron, Eastern Surplus, CSI, SECO, TNJ Murray, Coleman's Surplus,
Also, you probably don't want the zippered boots. If you do a search for "knuckle boots" there are a couple of threads with all the information you should need. (Cause I can't remember it all of the top of my head)
jasonjc
288
Gravette Ar.
Unless YOU have been in the front end befor, your best bet is to take the knuckle apart and replace in inner axle seal and clean and grease and check every thing out real good. Then you are better off useing the one piece boot. But thats just me.
daddy2
Easton, PA
I plan on tearing into the front end, but for now I will most likely get the zipper replacement. I just checked the torn one and it is a zippered kind. Too much snow here and cooler temps for me to rip into the front axle. I just want to get it done and
hopefully make Rausch creek. I took a look at the past threads and found a great one that had the pictures of taking apart the front end. Will most likely keep that thread in mind when I put the solid boots on in the summer. Thanks for the info.
