Steering Problem
Motorpool-Mac
Rapid City South Dakota USA
Has anyone had a problem with the steering being stiff? I have a 1948, 5 ton GMC with long gin poles on it that is mechanically very similar to the Deuce. It steers hard, but when I get the weight off the front axle by lifting a heavy load on the back the steering is easy.
At first I thought it was the steering gear box, but would it not steer hard with or without a load? Could it be the knuckle bearings? Any ideas would be great!
Thanks,
Daniel
gimpyrobb
dumpsterlandingfromorbit!
27,786
755
Cincy Ohio
Could be lots of things. If the ball joints are worn out, taking some weight off the front would help alot. Can you add lube to the steering box? Maybe that is dry. Lots to look for in the front end.
BEASTMASTER
142
Burgaw, N.C.
take the weight off the front again and grease the upper and lower king pins. have someone turn the wheel back and forth while you're putting the grease to them. i mean GREASE THEM.
