- 57
- 3
- 8
- SW WA
So after 1.5 years on the jack stands, I finally have the whole under carriage and drive train rebuilt and put back together. She is finally back up and running!
In the process I also upgraded to the 46" tires. However, now she swerves all over the road. If she starts to drift to the right a little, she quickly starts to swerve harder right. So you correct with a little left wheel turn and then she veers left and swerves that way. It's like it is a side to side see-saw ride.
I'm afraid to drive her anywhere. I checked over the suspension and steering linkage and all seems good and tight. Drag link was a little loose at the pitman and so tightened that up and re-greased it. But she still swerves. Anyone have any ideas? Could it be the larger tires or maybe she needs an alignment or something? Alignment wise, I measured between tire nubs and there is a 1/4" difference from front of steering tires to rear of tires. Is that significant?
Anticipated thanks for any advice or experience.
Cheers,
Rob
![Very Happy :grin: :grin:](https://www.steelsoldiers.com/images/smilies/icon_biggrin.gif)
![Confused :???: :???:](https://www.steelsoldiers.com/images/smilies/icon_confused.gif)
Cheers,
Rob
