Steering wheel questions
KI4FKW
Alabama
When I bought my truck it had a tiny GT steering wheel on it. I had the factory wheel, so I decided to put it back on.
Two things. First, the steering wheel has a little bit of front to back play in it. As in, you can grab the wheel and tilt it towards yourself and the dash. Not a whole lot, but enough to feel like crap. I searched here and watched a ton of youtube videos, but all I can find are things about fixing the loose tilt function with the three torx screws. The tilt function doesn't move. It is solid. It is the wheel itself that is loose.
Also, can anyone point me to details about the horn mechanism? I feel like I am missing something in the horn button.
Then, I need to align the wheel. I think I can figure that out, but as of now, its crooked with the wheels straight.
cucvrus
10,427
Jonestown Pennsylvania
That tilt column is not stock on the CUCV. I would say change it to a standard CUCV column. But they make a tool to tighten the tilt joint. I done it years ago and then I changed the column. Good Luck.
KI4FKW
Alabama
Full of surprises she is... well, everything on it works well, so I guess I will stick with it. I would like to fix the looseness and see if I am putting everything together correctly for the horn, if anyone is familiar.
joshuak
214
Slower shore, DE
Have you checked the nuts that hold the steering column to the dash image bellow from TM-34 and IIRC there are a couple more in the engine bay.
And here's an image from the TM-20 with details of the horn mechanism.
KI4FKW
Alabama
Fantastic, thanks.
The column itself is stiff. It’s only the actual wheel and yoke that have a little play. Not even the tilt part is loose, which i find is common.
nyoffroad
687
Rochester NY
Fantastic, thanks.
Never had that happen but to center the wheel is easy, just loosen the lock clamps on the drag link and with the engine running and the wheels straight turn the adjusting sleeve until the steering wheel is straight. Don't forget to lock down the clamps!
cucvrus
10,427
Be sure to turn the center that the link is drawing the threads in. I seen a few that were barely any threads holding the link together. You get the same results going the other way. Good Luck.
