Storage Container Shelf Bracket Source?
1800 Diesel
26
Santa Rosa County, FL
Probably off-topic but does anyone know a source for the steel shelf brackets that are found with the Cadillac (~9x7) storage containers? I don't have a photo available yet but the brackets are roughly 2" x 2" "double sided" and they slip into the vertical channels at the corners & center of the container walls. The channels that support the brackets have two rows of vertical slots & they are roughly 1" wide. The 3/4" plywood shelves are then placed on top of these brackets, (once the brackets are locked in place & leveled).
Thanks in advance for any info--have tried the google search route with no images coming up that match. Also since I don't have a TM for this item, I can't come up with an NSN for the brackets.
Kevin
1800 Diesel
26
If it is the same as the fiberglass mobility containers , try ss member
48cj2a
If you're talking about the Willard type FG container shelf brackets, these have spring-loaded pins that engage into vertical rows of holes to adjust shelf height. The ones I need are stamped & pressed steel with no moving parts--they slip into a double row of slots cut into the vertical channels riveted to the container's walls. Guess I better locate one of them so I can get a photo uploaded...
BTW, there's a good chance I'll be in your area over Thanksgiving...maybe we can go get a po-boy at Danny & Clyde's...after that head down to Cafe du Monde for beignets... :)
Thanks,
Kevin
Edited as marked in italics & underlined...
glassk
Hampton, GA
If you're talking about the Willard type FG container shelf brackets, these have spring-loaded pins that engage into vertical rows of holes to adjust shelf height. The ones I need a stamped & presses steel with no moving parts--they slip into a double row of slots cut into the vertical channels riveted to the container's walls. Guess I better locate one of them so I can get a photo uploaded...
Thanks,
Kevin
48cja2 sent me some of these, although not for the Caddy lac's ,,,lol
juanprado
2,915
Metairie/La (N'awlins)
Thanks,
Kevin
I would be glad to meet you! Pm sent with my info.
EdwardThirlwall
NSW
I think shelf brackets for storage containers need to be a little bit sturdier. You may want to just gauge the height of the storage unit first so that you can get a better idea of how many you're really going to need in there. Obviously because the whole thing's gonna be on the move a fair bit, you may want to get something that locks down a lot better too.
zebedee
conceptualizer at large
724
Central NY
