Strange CUCV Gen 1 light issue
ranchhopper
136
south elgin illinois
I was going through the search to see if any of the threads covered the generator 1 light issue occurring with the 1009 and none quite matched up. As its gotten colder when I start the truck the gen 1 light lights up when I hit the accelerator the charge gauge jumps up into the green but the light doesn't go off it will gradually fade to a light glow but not go off. I checked and no bad wires or fusible links the only thing different is when the lights are on both turn signals light up on the dash its done that since I bought it from bad grounds in the light sockets. Now the left turn does not light up anymore when switching on the lights the light will brighten up when hitting the accelerator after it fades a bit I checked the battery cables all good there strange that the gauge shows a good charge on the gauge. I don't own a multi meter so I have not checked voltages I supposed I should get one with the electrical issues these trucks seem to have.
1,172
Time for an alternator rebuild.
1,172
Alternator rebuilding is not difficult.
Your voltage regulator is the likely issue.
1,172
Use an impact to remove the shaft nut.
The rest is simple hand tools.
If you replace bearings, do not hammer them in without "backing" the housing or it may break.
Pay attention to the locations of the washers/spacers/ and insulators.
It's 100% covered in the TM (-20 iirc).
Once you have done one, it takes less than 30 min to do them.
Here is one of the multiple threads covering it. https://www.steelsoldiers.com/showthread.php?146703-CUCV-Alternator-Rebuild Found in the FAQ/ Wiki, or whatever we call it, in the cucv forum stickies.
sneekyeye
133
ALABAMA
If you're up for rebuilding your own alternator, you really ought to tackle those light sockets with the bad contacts too. Back feeding electrical currents can cause all kinds of annoying problems that could pile on each other and seem more serious than they really are.
Milkman357
15
Des Moines, IA
Generator #1 is the Passenger side Alternator?
Oil pressure light and Gen 1 light stay on after I turn off the engine. Pulling fuses do not make the lights go out.
The left indicator light on the dash also has not worked for awhile. ( may not be related)
This kills the battery.
I have a back up / parts M-1009 to swap alternators with....
Generator 1 is on the Drivers side?
Sounds like I should clean and check the terminal connections first.
