Strange knocking/rattling noise in rear
galeo7171
Cumming, Ga
When I let off the gas I hear a loud knocking noise coming from the rear of the 1009. I did notice that my right rear tire has no wheel weight, so maybe its causing enough vibration to rattle something?? What could cause a loud noise in the rear end when you let off gas? It seems to happen only at certain speeds too
HeadWizard
Chantilly, VA
Wheel weight wont make much difference on that large a tire.
Is it a noise ONLY when you let off the pedal, as in ONE clunk, or does it make more than one noise - as in continuous noise. If it's a one clunk thing, its either a u-joint or excessive ply int the rear 3rd member.
