Strikers on M211/M108 Hybrid
firefox
General
51
Berkeley CA
I just put Striker singles on my M211/M108 Hybrid that I rescued from the
crusher. I had to mount them as the outside position of duals since otherwise
they would hit on part of the frame.
Will this put excessive stress on the axle assemblies?
Although this truck will be used for light construction and help with fixing
other MV's, it is not going to be used for heavy offroad use.
I will attempt to show a picture of the truck before the new wheels were mounted.
Thanks for any thoughts.
Bruce
ALFA2
Phoenix, Arizona
firefox, this will not put undue stress on the axles, since they would not carry the rated load over the road, and not at rated speed. If the bearings are OK, and have grease this should be OK for a while.If at some point in time you decide to do a long road trip, and or tow another Deuce a long distance you may want to get better tires on that truck.
Hope it helps.
ALFA2
