stryker rims can run on a 5 ton
calvin3103
ewa beach HI
dose any one know if you can run the stryker rims on a 5 ton , i know the center is larger hole than a five ton rim, is it safe if it bolts up.
4,674
You won't even get it over the brake drum. They barely clear on a 20" rim. The Stryker uses only a 325/85R16 tire and 16" rim. Also the bolt pattern and hub opening is totally different.
