stuck
bigmike
354
Dixon CA.
You should be able to make short work of that hole with those super singles!
rizzo
Port Huron, MI
Re: RE: stuck
your right, no problem on the other hole. I think guys with 60' tractor tires had made the ruts I got stuck in.
Towman2277
Saraland, Alabama
RE: Re: RE: stuck
That is a deep one..... I do lot's of mud riding, and i've learned that if I start to spin and stick, I can usually grab third in low range and "Spin em" and that will help "Clean" the tires of the already caked mud, and it helps 90% of the time to go own through, as long as you still have some motion. Man, I love my winch though!!
rizzo
Port Huron, MI
Re: RE: Re: RE: stuck
EastCoastKaiser said:
Where's that white pick-up that pulled the 60K wrecker out when you need him..... : )
LOL funny, you heard that was a setup right?
we tried to pull the M810 out with my deuce, but the motor was dead, so we got the JD 450 dozer over there and jumped the bats, then pulled no problem with the motor running.
