Studebaker Transfer case Mounts/bushings
lowrdrbird
Ohio Dayton
Hey Gang
Here is my next problem that I have ran into..... I am about to put the transfer case back onto the frame of the studebaker. And I need 8 spring bushing/mounts. The one for the Engine is the same size in diameter but is about 1/2 too tall. So I cannot use the intended bolts.
Now here is my question were these the same mounts as used on the CCKWs???? If so anyone have 8 that I can buy or trade for???
Please let me know
Ken
NDT
7,533
Camp Wood/LC, TX
On the split axle Jimmy, the Timken transfer is bolted right to the crossmember with only bolts and spacers.
swordmd
Mountain Home, Idaho
You lost me on that one. Both of mine that still have transfer cases in them are mounted with round rubber dounuts with studs, castle nuts and wire. No springs.
lowrdrbird
Ohio Dayton
Okay here are the pics of what I have.
The rusty one is the mount for the Transfer case looks similar to the engine Mount the one on the right. But it is smaller in band size but same size in diameter.
The Engine mount is about 3/4 of an inch and the transfer mount is about 1/2 inch
Where can i find these transfer case types??? I can also use the rubber ones also but cant find those either.
Ken
:lost:
