Sunday winching gone wrong...
1,177
Wait til you see the broken driveshaft pics.
1,177
Huh. Why was the winch even needed?
The excavator was a rental and it had very very little hydraulic power. It could not lift the machine. It also had one side that would barely drive.
The hoe sat overnight there , and the rear counterweight was totally submerged this AM. I am surprised it started. They could not rotate it either, until I dug around it with my backhoe.
After my driveshaft broke, I called in a friend with an old Holmes 550(I think).
MY winch cable was brand new. It looks like the tensioner did not travel across the arch, and that allowed the cable to bind on itself, causing it to snap. (that's my best guess).
All this damage with a true military issued shear pin installed.
abh3
Florala, Al
Things I've learned over the years: 1) Don't go in the s**t on an excavator w/ weak hydraulics! 2) Be really careful dragging yourself out with that long-stick machine if the hydraulics are strong!
1,177
No way that was going to work but I would have tried anyway.:grd:
The tracks were parallel to the shoreline. One was under the mud/water by about 2'. The other was above the water and sort of on hard ground.
The idea was to have the boom up and use the winch to tilt the machine(sucking it out of the mud slowly) up onto the high side track, then let him drive sideways to the cable pull, onto hard ground.
That was working until the cable snapped(I suspect from the tensioner not working correctly) I have completely cleaned and lube it too.
When the cable broke, I had the low side track lifted up about a foot.
porkysplace
1,493
mid- michigan
Did you have wood mats under the excavator?
RealCavDog
12
Joplin, Missouri
Makes a few of the debacles I have been in, VERY recently, look pretty tame and manageable ! I am just so glad nobody was hurt, and that there was not any more damage done !
:beer: For an excellent effort ! :beer: AND for the great pictures of the adventure !
1,177
No, but we put several trees under the track, with my backhoe.
This mud was black sand and about the consistency of mashed potatoes.
I was not the guy that got the excavator stuck. I was the guy they called to get it out.
After about 8.5 hours, we did get it out.
