racing4funn
- 0
- 16
- Chattanooga Tennessee
I removed the CSIT air system and one the the stems in the center threads are distroied. So I cant screw in a center pin. My only guess is the take it to a semi truck tire place. Problem is the complete stem that bolts to the rim needs replaced and they will not have the same matching part. If I could get the stem then I could pull the tire apart and replace it since there are not special tools needed.
