aw113sgte
- 1,424
- 93
- La Crosse, WI
Looked around a bit but seeing so much different info and a lot of it is for prior than A1R trucks. Best I can tell, I only need the alternator for the upgrade as I have the single belt, supposedly correct alternator bracket?
Plan is to power a mini split and use for both cab and habitat cooling. From the wattage requirements, seems totally doable with the larger alternator, obviously some ducting will be needed.
