Swapping Axles 116 to 101
mkcoen
381
Spring Branch, TX
I have a M101 and a M116A1 gen set trailer. I'm thinking about swapping the axles so I can have surge brakes and GM bolt pattern wheels. I don't forsee needing to tow the genset any where but I'm thinking of taking the 101 on the MVPA ALCAN Convoy next year. If I'm pulling it behind my M1010 then all the wheels would match and no need for different spares.
Pros/Cons?
Nonotagain
41
Parkville, MD
Pros/Cons?
Why don't you just swap the bodies? There are around 12 studs on the frame that attach to the bed. Easier as far as I'm concerned than breaking the u-bolts loose and still having to swap the lunette over plus the brake tubing.
timntrucks
Ponchatoula LA
yes a bed swap is the way to go.. ill be doing a similar thing in a couple weeks. fresh rebuilt 101a1 with fiberglass rails swaping out with a A2 that is tan.. ill paint the frame on the a2 green and then ill have a super new A2. then put back the A1 paint it vietnam green. been looking for a camo A2 to long .. i have given up so ill build my own..
mkcoen
381
Spring Branch, TX
Problem with swapping beds is having to pull the 10kw off the 116 and then swap the beds. Seemed like jacking them up and rolling the axles out would easier.
1,807
Anybody the the neighborhood with a wrecker? Makes short order of swapping beds, empty or loaded!
Nonotagain
41
Parkville, MD
If you are concerned about having all the same wheels on both tow vehicle and trailer (which I agree with) why don't you purchase a commercial axle with electric brakes? You gain service brakes but give up the parking brake.
I'm not sure if you can just unbolt the front half of the A1 trailer and mix and match between an A1 and A A2. You're going to need the lunette/master cylinder as well as brake lines to make the brakes functional.
Jacking up the bed and spanning the width with 2X6" lumber sat on saw horses appears easier to me than attempting to get 20-30 year old U-bolts broke loose.
mkcoen
381
Spring Branch, TX
I think by the time I bought a commercial axle and did all the work I could afford to just buy a M101A2 (which I might just do). I have a spare master cylinder lunette already so the brake lines and axle were the main concerns and I can bend and flare my own lines. The aggravation of doing either swap almost seems to make purchasing a different trailer the best way to go. My 101 was just overhauled with new paint and fiberglass racks before it was turned in so I'm sure I can sell it for enough to cover a different trailer.
hjoed
Downey, CA
Adding surge brakes to m101
I'm dealing with the same dillema. Bought a great looking M101a1, but hate to burn my brakes on trips. I wan to do surge brakes and want to swap out the M116 frame completely. According to TManual, it is a few bolts. Lifting the Gens sounds like a huge effort though. Why not just cut the bolts off and put in new ones when reassembling?
mkcoen
381
Spring Branch, TX
I've got 4 trailers in the driveway now (101, 116, 105A3, MKT). The "Mrs" would be happier if we had fewer. She would be even happier if her truck would simply be ready to go. One of these days I'll figure out that making her happy makes everyone happy.
