bjsmith
- 1
- 0
- zachary,la
anyone know where i can get a good soft top complete with everything needed as i have a hard top now
They were a "take-off" from another Deuce - all is OEM. If you look at the top "pipe" where the "bows" fit into you should see three mounting holes. There are also three mounting holes on top of your windshield frame. On the other hand, you have a 5 ton, so it may be a bit different. Some of the other 5 ton owners here would know for sure...MacGowan,
These bows from the rear frame to the top of the front window (your first pic), which keep the soft top up, are these standard or home-made? My truck has a soft top but no bows. The new canvas OD-colored soft top I bought also did not included them.
James
Hmmm... I'm not a Deuce expert, and certainly don't pretend to be. With that said, my Deuce came with a hard top (I understand that doesn't mean it was original), but upon removing the hard top I found the three holes necessary to install the soft top. There was rust everywhere you'd expect EXCEPT for the soft top mounting holes - doesn't look as though they were ever used. My Deuce is a '67, so perhaps the M44 platform was changed to provide the soft top option prior to '67? Thanks for the info Jake.I believe at some point in the service life of the M44 platform, those were introduced. There was an MWO with instructions for how to drill those holes. Newer hardware came with them. At least that's how I understand it.
There was also something (Might not have been a MWO, maybe Connie said it?) about adding holes and extra bows towards the outside edges, nearer to the doors. I don't recall if that was rearranging the three bows, or if it was adding additional ones...
All of this was unit level stuff.... So whatever you do and wherever your drill happens to fall and however deep you choose to make the holes would probably be quite authentic, even if not technically correct.
