You will have to add a relay. there are manufacturers that make aux fuse panels with a relay which would be a fairly straightforward install, except you will need a relay with a 24V coil... Something like this one I found on jegs website.I am looking for the switched circuit for adding 12v accessories (stereo, nav, etc) that I want to shut off with the ignition switch.
