T-case question
IHASFIP
TEXAS
How hard is it to get your t-case in low? And what is the exact procedure per the TM. I searched and couldn't find anything. My t-case is a nightmare to put in low. You pretty much have to get rolling about 10 mph and stand on the lever to get it in...probably not the best of ideas. Any ideas? Also, one quick question, there is a little do-dad on the driverside of the motor towards the front of the truck in front of the fuel filters, kinda above the FDC that has a small silver know on it that you can kinda turn its spring loaded. What is it?
D
Stretch44875
Super Jr. Moderator
30
Tiro, Ohio
silver thing have a knurled knob? Should be an oil sampling port, just twist when the engine is running and oil comes out.
Transfer case hard to shift into neutral or high?
joshgar8
Nashville, Tennessee
I just had to do some work on my transfer case. I was having problems with it staying in high. The problem was that the adjustment on the shaft inside the gear box wasn't set right. The set screw on the adjustment was safety wired in the inncorrect location not allowing the spring detent to engage in high. You might want to take the cover off and take a peak in there to see that all that is correct. But with it going in with the truck rolling, it sounds like it might be something alittle bit more intence:cry:
IHASFIP
TEXAS
It goes in high, and neutral just fine. And it will go almost into low, but just not quite far enough, thats while sitting still. I can cram it in sometimes, but only if moving. I have to take some pictures, I think I have an idea what the culprit is.
D
chicklin
Kansas City, MO
Any follow-up on this? I have a similar issue but I can't get mine to shift into low at all (moving or stopped). Feels like it's running into a brick wall.
