T-Case slipping
bp m1009
Somerset County NJ/ NE PA
i have an m109 and it seems like everytime im in 4lo it will randomly pop out of gear and make a grinding sound because the gears are still spinning when it pops itself out of 4lo. I think it only happens if it suddenly stop (hit a big hole) or if i start to approach an incline. is this normal or is this something bad? or am i just doing something wrong?
1,176
Not normal. Look at you linkage adjuatment, and your motor and t-case mounts.
bp m1009
alright i gotta look that seems like it would be it cause when in 2wd the little 2 lines that highlights what your range your in likes to slowly slide down below 2wd and i push the stick back up every now and then.
