T1138 Ratios
simp5782
Feo, Fuerte y Formal
9,322
Mason, TN
Can they be mounted vertical or canted slightly for passenger side drop?
They are already a drivers side drop as the oil pickup for the pump is on that side.
You would be better suited to run a shaft to a center support shaft bearing to change the angle.
They need a pump for the overdrive high speed or they will burn up.
