Tail light out question
roveroverme
Banned
350
port saint lucie/ florida
I heard that my tail light goes out when I turn the right flasher on , have the headlights on and step on the brakes.
It doesn't do that on the left side apparently. I cleaned the ground and changed the bulb, but the symptom stays the same.
I noticed a black and a white twisted wire dangling from the fuze box but I haven't messed with that , yet.
Any ideas on what could cause this?
cucvrus
10,076
Jonestown Pennsylvania
I think the black and white wire that is hanging from the fuse box is the seatbelt warning wire. It goes to the seat belt retractor and the light stays on till the seatbelt is fastened or a short time which ever comes first. My first guess with out seeing it is that you have a bad light socket. They are notorious for the small thin ground tab to break off.
o1951
155
Bergen County, NJ
Caused by high resistance somewhere in the circuit. A voltmeter can quickly diagnose the problem.
On older equipment, you need to look for corrosion where the terminal is connected to the body
AND where the wires go into the terminals.
The connector can look good, but there can be corrosion in the wire under the insulation.
The high resistance can be anywhere in the circuit. Even inside the light socket.
If I were doing it, I would duplicate the condition.
Get a wire long enough to go from batteries to taillight.
Get an inexpensive VOM.
Get a inline fuse holder and put a low amp fuse in it - say 10 amps.
You can get this at Radio Shack or similar store.
Connect one wire of the fuseholder to the end of the wire at the battery, and connect the other end to battery ground.
The fuse is in case you screw up.
Duplicate condition. Use a stick to hold brake pedal down.
Connect meter between end of fused ground wire and ground on taillight terminal.
If it reads more than a volt or so, then you need to R & R taillight ground.
You can test at various points to find where the fault is.
Dielectric grease is your friend.
When the ground circuit is ok, if you still have a problem, you can trace back on the hot side and find any problems.
Leave the wire and meter connected, and starting at the bulb socket, work back to the switch.
At some point, you will get close to 24 volts.
You know the problem is between where you have 24 volts and very little.
Corrosion can be anyplace. In the wire, in the socket, in switch.
There could be a nick in the insulation from long ago. That allows moisture to enter, and over the years, slowly corrode the wire.
The advantage of testing this way is you are working with the ground side, not 24 volts.
The wire from the battery is at ground potential, the meter, except when the probe is touched to hot side is at ground.
In case you mess up, there is a fuse.
Anyhow, disregard everything I said.
Do at your own risk.
I am off my meds and do not know what I am talking about
cucvrus
10,076
I think they may have replaced the light fuse with an in line fuse. I am sure that is what they did. It will work that way. No worries. I have an M1009 that has a couple of them in line fuses tapped into the harness. If it ain't broke don't fix it. You have a good looking truck. Good Luck with the truck.
