Tap N Die Starter Bolt holes. Yep it happened.
OuttaTheWayPECK
Topping, VA
1985 m1009 6.2
So, finally happened the starter bolts both broke off up in the block yesterday. thankfully in my driveway. started attempting to drill them out. the extractor kit I had didn't do the trick. So got some new one extractor kits coming, got new starter bolts, but might end up having to rethread the block. possibly. has anybody covered the right tap n die sizing for this situation yet? The set I have is missing most of the kit. I can buy individuals so if anybody has a direction for me, I'd appreciate it. This job might seem simple to some but I've never been down this road before, so any help and advise would be greatly appreciated.
Rutjes
272
Amersfoort, The Netherlands
1985 m1009 6.2
I recently had a starter bolt break off. First time experience for me too.
I got a reverse drill bit, took a bit of asking for at different stores, but finally found one that could get me one.
After a bit of very carefull drilling the drill caught the broken piece and drove it out.
Sent from my A0001 using Tapatalk
1,178
Did you have a support bracket on the front end of the starter motor?
snowtrac nome
139
western alaska
The answer to your question is what size is the threads, they are 10 mm x 1.50 thread pitch they should come out easily unless some expert used red locktite. I never use a thread sealer on them as I know some day they are going to break and I will have to extract them.
I have seen a few instances where the threads got bugered from some one extracting them wrong or cross threading bolts in that case I drilled them over sized and used thread inserts. Good luck if they have red locktite you will likely have to use an oxy gas torch to get the fastener hot enough to remove it.
snowtrac nome
139
western alaska
Usually not because the threads are recessed. you should use starter bolts for a gm product, not just some bolts bought from your local fastener shop.
cucvrus
10,427
Jonestown Pennsylvania
Just for the record. The 6.2 has metric M10 X 1.5 bolts on the starter.(As Mentioned) I have seen many that they used 3/8" x 16 bolts. And they held but not as tight as they should have been. Just for the record. The thread pitch is that close between the 2. Have a Great day.
dependable
188
Tisbury, Massachusetts
If you can't back it out with a reverse drill and extractor (defiantly try the drill first), you can use drill it out and use a correctly sized Helicoil. I had to do this years ago on my first 6.2 shortly after I bought it. The repair lasted years until the truck was retired due to rust. Just be very careful drilling it out, you only get one shot at it.
OuttaTheWayPECK
Topping, VA
you guys are awesome, thank you! I drilled and bought a couple extractor kits. I broke like 4 regular bits, broke like 6 left handed bits, one reverse bit grabbed one of the bolts way up there in the block. (nope I didn't have any sticking out of the block to do the weld a washer trick on) so, basically, carefully and sometimes not so carefully drilled the **** outta the one hole. wasted some of the threads, but still have thread enough that I was able to buy new hardened steal bolts and got the starter back up there and tightened down and snug. answer to a question, yes I have the front bracket. after dealing with the holes. I noticed the front bracket wasn't tight at the frame bolt side. it was able to swing away. so I think I know what happened. I think, the front bracket loosened, left all the torque on the 2 back bolts. and just snapped them puppies. thankfully I did not have to rethread the block to a larger bolt pattern. All is well. lesson learned here for me is, do more preventative maintainence more frequently to catch simple issues before they become a big problem HAHAHA. Thanks everybody!!!
