TCM J2 fabricated diagnostic cable
wildchildsteel
el paso, tx
I am looking for a diagram on how to wire up a diagnostic cable from the J2 port on the TCM to a OBD port. I have seen the instructions before, just cant remember where.
With this you should be able to use your own diagnostic reader instead of a MSD/ICE.
Action
1,553
East Tennessee
If you are having a problem with the TCM, it will flash any trouble codes. And there is a list of all codes for these.....The TM shows how to retreive codes and has the list.
Retiredwarhorses
4,054
Brentwood, Calif
it will only flash codes with the diag cable installed...this info is in the TM’s.
wildchildsteel
el paso, tx
I am not talking about a paperclip nor a diagnostic cable with a light at the end. There is actually a cable that goes to a piece of diagnostic equipment like a MSD/ICE or maybe a TECH 1 or a Snap on solus. With this cable hooked up to your diagnostic machine, You can read data from your sensors, solenoids and torque converter.
