- 7,409
- 2,501
- 113
- Interlachen Fl.
I'm going to get you guy to hate me one way or the other.
Tech tip. When draining your air tanks bleed all the air out of the inboard tank (on my rig) lets call it the main first. Let all the air out. Now we can see if the check valve is holding between the tanks. Secondary tank should have good pressure. If not check valve is not holding. Mine was bad had crap in it an was not sealing. I got my valve from NAPA but went with 3/8 thread cause I broke the block that went in to the tank and 3/8 block is what they had.
