technical data for the bulb that is used as speedometer illumination - M1009 / Chevrolet Blazer K5 6,2 Diesel
Elektroman99
144
Siegburg, Germany
Dear Steel Soldier Community,
Topic lighting, respectively light bulb
Unfortunately, my Chevrolet Blazer is not at my front door.
Therefore a question, which you can answer me if necessary?
I need the technical data for the bulb that is used as speedometer illumination.
Is this a "W5W W2.1x9.5d T10 5W 12V bulb" and what is the real "base", is this the "W5W" or the "T10"?
Does anyone know in which TM document is written something about this?
Best regards
Elektroman99
antennaclimber
1,096
State College, PA
From the TM, it looks like that is a standard automotive 168 bulb.
W5 W5W WW2.1×9.5d16 V, 12 V, 24 V: 5 WECE nominal luminous flux: 50 lm ±20% T10 size
Old designation: W10/5 ANSI № 168
Info from the internet:
W5W Bulb Equivalents
The W5W has many crossover equivalents including the 194, 168, 147, 152, 158, 159, 161, 168, 194, 192, and 193. So the W5W shares the exact specifications as the 168 bulb. That means you can interchange W5W and 168 bulbs, or replace both with T10 or 194 bulbs if needed.Aug 18, 2023
Item 21 should be your bulb.
SECTION II TM9-2320-289-34P
(1) (2) (3) (4) (5) (6)
ITEM SMR PART
NO CODE CAGEC NUMBER DESCRIPTION AND USABLE ON CODES (UOC) QTY
GROUP 0607 INSTRUMENT OR ENGINE
CONTROL PANEL
FIG. 42 INSTRUMENT CLUSTER ASSEMBLY
1 PAOZZ 96906 MS90724-34 NUT,SHEET SPRING 4
2 PAOZZ 11862 11513932 SCREW,ASSEMBLED WAS 4
3 PAOOO 11862 25052807 PANEL,INSTRUMENT 1
4 PAOZZ 11862 25053623 .PRINTED WIRING BOAR 1
5 PAOZZ 11862 25015099 .GASKET 2
6 PAOZZ 11862 25022883 .LENS,LIGHT 1
7 PAOZZ 70040 6433429 .INDICATOR,LIQUID QU 1
8 PAOZZ 11862 25017376 .BEZEL,INSTRUMENT MO 1
9 PAOZZ 11862 6497476 .LENS,LIGHT 2
10 PAOZZ 11862 6497483 .GASKET 1
11 PAOZZ 11862 6497475 .FILTER,INDICATOR LI 1
12 PAOZZ 11862 25022884 .FILTER,INDICATOR LI 1
UOC:194,208,209,210,230,231,252,254
13 PAOZZ 11862 25053501 .FILTER,INDICATOR LI 1
14 PAOZZ 11862 25053500 .FILTER,SIGNAL LIGHT 1
15 PAOZZ 11862 25076586 .FILTER,INDICATOR LI 1
16 PAOZZ 11862 25053622 .CASE,INSTRUMENT CLU 1
17 PAOZZ 11862 8986000 .CLIP,ELECTRICAL 3
18 PAOZZ 08806 194 LAMP,INCANDESCENT 1
19 PAOZZ 77060 2973932 LAMPHOLDER 14
20 PAOZZ 08806 194 LAMP,INCANDESCENT LEFT 1
21 PAOZZ 08806 168 LAMP,INCANDESCENT 12
END OF FIGU
Hope this helps.
Karl
