Technical Manual
Knottofs
White Level, NC
Id recommend calling Boyce Equipment, and asking for Bret, Mark, or Shiloh. Last time I talked to Bret, he said they had a number of Tec manuals for the M715 / M725. I just haven’t had time to investigate any farther. Ive got the Operators Manuel, which really isn’t anything, but ive also got a 2 pager on the “Kaiser Jeep Model 6-230 140 HP Tornado 230 Engine.” It covers Ignition, coil, ignition timing, Spark plug, and Distributor Mechanical Advance info. If you want, I can scan it and Email it to you. If you find anything on the Engine specs or transmission and transfer case, let me know.
Hope this helps, Nate
1-800-784-4269
http://www.boyceequipment.com”
