Technical Manuals
Hwhomes
Moses Lake WA
on the TM thread there are 9 different manuals listed for the LMTV's. Are they all different and covering different aspects of the vehicles? Or perhaps for different years/models? How do I tell which ones are relevant to my specific vehicle?
MtnSnow
17
NSL, UT
Yes there is totally different ones. such as Operators Manual, Parts, etc As for picking which ones apply to your vehicle open the PDF's and see if your vehicle is listed :)
Guyfang
27,314
Burgkunstadt, Germany
Look at the data plate on your equipment. Write down the modal number and NSN. Look at the cover of each TM. Find the proper model number and NSN. That book is for you. Then look in the section of the Parts Manual under Usable on code. Find the usable on code for your equipment and write it down. When ever looking up parts for your equipment, make sure the Usable on code, (UOC) listed next to the part you are looking up is the same as what you wrote down. I down loaded all the manuals I needed for a generator and then took it to a printing shop. Had it printed out and put in plastic document covers. Makes for BIG books, but if you use them lots, like I did, it was worth it.
NDT
7,509
Camp Wood/LC, TX
I think what he wants to know is: -10 is operators manual, -20 is organizational (mid level) maintenance, and -34 is depot level maintenance. The corresponding numbers with a "P" suffix are parts manuals applicable to that level of maintenance.
