Temp senders / switches locations
I am wondering where the locations of all the various temp switches are and what ones are normally open, normally closed, and at what temps?
There are ones for the cold advance, the glow plugs, temp light, fuel heater, and one in my thermostat cross-over. These are the ones I am curious about.
Warthog
231
OKC, OK
The thermostat cross over sensor is not stock to the CUCV. It is stock on the HMMWV.
The TM 9-2320-289-20P and TM 9-2320-289-34P have all of the sending units listed (you do have to page thru them).
I do not know any complied list. You can always look up the part numbers and see what the specs are.
Seems like Antennaclimber has posted the GP sensor specs before.
Found it, Thanks!
The engine is from a HMM-V
Cross-over switch, Glow plug switch by the #8 cyl, and cold advance in the right rear block-off plate on the head, all are normally closed, and open the circuits (cut off power through them) at around 120 degrees F.
