Temperature sender wire
Sjoconnor
Marshfield MA
So, since getting my 998 in August the only concern I’ve really had is operating temp. I’ve read everything I can on the matter and have replaced pretty much everything and with a laser thermometer it runs nice and cool but guage (new) shows 230+ once warmed up.
I have it in the garage to redo a bunch of things and wanted to run a fresh wire from guage to sender. As I looked real close yesterday, the current wire has been spliced together. I’m assuming that’d mess up the resistance and in itself give me false reading.
Looking thru the TMs I cannot find the wire number which I need to replace from the guage to the sensor. There is no metal tag on the spliced wire.
any help is greatly appreciated from those who’ve done this.
DREDnot
443
Phoenix, AZ
I found this list of circuit numbers while I was cleaning up my wiring following a hi beam indicator replacement.
I looked up all the numbers from the dash connectors and sure enough...the numbers matched. Leave it to the military to have a uniform numbering system.
Anyway...the wire from the temp sender to the gauge will be a 33. I think mine was 33A. The power feeds to the instruments will be a 27. You should see 27A, 27B, 27C...they are each a common power feed to the instruments
Sjoconnor
Marshfield MA
thank you for that. Hopefully this issue is behind me.
