Tension on Air Compressor belt
Levi75
13
Spraggs pa
I figured out how to put tension on the air compressor belt, and after tightening up the 2 bolts, and running the truck a few miles, the belt now has slack in it again. Back to where I first started. Can anyone tell me what is going on?
Thank you!
ToddJK
4,512
Sparta, MI
NDT is correct. However, you do not want to over tighten that belt which will stretch it further. There's not a lot of tension on the air compressor pulley like there is on the other pulleys which have two belts so a little play acceptable.
kenn
513
Texas
I was chasing gremlins today and noticed that my compressor belt "dances" quite bit but doesn't seem loose. Historically, belts I've seen on engines stayed pretty straight but mine seems to move a good bit. I'll try to get a video.
kenn
513
Texas
Ok, my belt dances like that video, too. I don't think there's an issue with my pulley, though.
ToddJK
4,512
Sparta, MI
Yeah, that dancing around is what I mean by "play". As long as it's not making contact with anything else, it's fine. If it does and the belt has tension on it, then there's an issue with the pulley or possibly even a defective belt.
