Tensioner and serpentine belt replacement
Cybul
71
Poland
Hi.
I need to replace tensioner and belt in my 1152A1 with A/C (S/N 251798 ).
I have checked many shops and ebay auctions and I see that there are very big price differences there. From ~70usd to 600usd.
I also found some copies in china shops for 60-70usd. So probably those with low prices on ebay are also from china.
My guess is that the cheap Chinese-made ones are not of very high quality, but maybe I'm wrong.
I have checked that there should be NSN2920014912011 or other?
I also need to buy belt.
I have 400AMP:
and I've checked that this NSN 3030-01-445-6964 number ( 111.02 IN ) is for a fixed pulley version like this:
I have:
So should I buy 3030-01-445-6964 or 3030-01-524-2460 ( 126.49 IN ) or maybe 3030-01-583-7508 (110.31 IN, it's for 400 AMP with PULLEY 12518548, this pulley looks like my ).
Probably the last one, but I'm not sure.
In TM-9-2320-387-24P.pdf I have found only parts for vehicle with 200AMP.
Where I should buy good quality tensioner and other parts?
And what is it, by the way?
Coug
4,764
Olympia/WA
Item in circle in 4th picture is your power steering reservoir. It should be filled with the same automatic transmission fluid as you use in your transmission, usually either DEX III or DEX VI, though DEX III is commonly recommended for applications other than transmissions (can usually be found as DEX/MERC fluid)
Tensioner can be found through the reliable vendors, Hummer Parts Guy, Kascar, MacMotors. Looks like MacMotors has it for under $200
As for the belt I can't help much as I am not as familiar with all the variations for the later trucks.
Cybul
71
Poland
Thanks Coug for a vendor list.
I just get confirmation from Hummer Parts and Mac Motors that I should order those two:
2920-01491-2011 tensioner Part Details - Mac Motors
33030-01-488-5606 belt Part Details - Mac Motors
So if someone has similar config: 400AMP (with A/C) without fixed pulley but with the big hex nut on the outside holding it on, then should order the above parts.
