Testing a Starter......step by step
232
Sault Sainte Marie, MI
some of you may have seen my starter problems, I have a new one to test now but I'm not having any luck. I'm 99% sure I'm doing it right but I would certainly appreciate a step by step to make sure I'm not having a slow day (in the head). Any advice or pictures are appreciated.
rosco
30
Delta Junction, Alaska
If you want to test run the starter on the floor with battery cables, hook the negative/ground lead to some substantial part of the starter housing. Hook the hot lead to the large solenoid terminal, marked +24 in the picture above. The with a small jumper wire,make a momentary
rosco
30
conection to the +24 terminal & the (+24) small terminal. Be prepared for the starter to jump on the floor with torque.
Might want to hold it down with your knee, or even put it in a vise.
Lee in Alaska
