Testing ABS ECU
droprat
Las Cruces, NM
I am parting out an M-931 and need to test the ABS ECU to see if it is still good.
Any suggestions?
A large portion of the truck has been removed, (No gauges, no ABS light, No air lines etc)
Thanks in advance!!!
juanprado
2,865
Metairie/La (N'awlins)
You would need an infocentre code reader to hook up to the diagnostic port.
Did the light stay on past the 3 second start up? Where you able to drive it all and did the light come on?
If the light did not come on, I would say there is a high chance the electronics would be good.
