testing your alternators
carctruck
Blaine/Mn
Im looking through the maintenance manual on testing alternators, and Im sure everyone else has seen that a test bench is the preferred method for testing. My gen 2 light is sweeping bright to dim, and Im reading 30VDC cycling to 28VDC in sync with the light, meanwhile my voltage gauge stays motionless at the high end of green. Anyone else have this happen to them?
niferous
Houston, TX
My Gen 2 light comes on sporadically web though the alternator was rebuilt. The voltage does not drop and the alternators test good. Any ideas? It only does it at idle.
Warthog
232
OKC, OK
Just because the alternator was rebuilt doesn't mean the parts are good. I have seen new "china" parts fail before and shortly after installation.
Have it tested.
niferous
Houston, TX
Have it tested.
Have it tested at a shop or test it myself on the truck? They both put out the required power.
gaunt1969
bessemer, al.
sounds like the voltage regulator. you can get the parts for around $40 and do it yourself in less than 1hr "30 min" if u done it b-4. its very easy to do.
