You're a fresh CUCV face on Steel Soldiers so welcome aboard and tell us a little more about the truck's future.
Are you plowing with it as well or retiring the truck for Friday night cruises?
We added a transmission cooler but it doesn't make complete sense without a transmission temperature gauge. No sense cooling a transmission when 'straight' plowing in temperature's below -20C because "optimum operating temperature" is the real goal with most transmissions.
We put an isolator switch on our cooler so I'd turn it on during hot highway runs and the odd time I was R/D/R/D/R/D plowing....which is avoided because it's hard on the CUCV.
In addition to the list of related threads at the page bottom of each "well titled" thread, I found an old link with some real good CUCV transmission info regarding temps.
http://www.steelsoldiers.com/showthread.php?63660-TH400-temp
When a guy can afford to put the best of anything together, you probably should. If the shop is reputable and stands behind the work it's a win/ win situation for both of you.
We're hearing rumors that parts of Alaska missed winter so what's the real story out of Homer?
