- 3,495
- 3,370
- 113
- Brooklyn, NY
1987 M1025. 6.2 L normally aspirated stock engine. TH400 transmission. Stock tires and transfer case. Stock pumpkins front and rear.
If I place a mild turbo with less than 10 pounds of boost and water injection, what is the best shift kit or after market modification I can place on the transmission that will improve shifting in a city environment? Should I keep the stock torque converter?
Is there a favorite transmission rebuild kit?
Is there any reason not to run a full synthetic fluid set in the engine and transmission and transfer case and pumpkins?
Has anyone of you guys added a second fuel reserve tank in order to run waste vegetable oil and or bio diesel?
Do you guys have a favorite brand of brake pad?
TIA
T
the bulletin board search function is somewhat helpful but I am still left with too many questions.
TIA
T
