That small run of rubber fuel line at fuel pump.
Warthog
232
OKC, OK
The line from the frame to the pump is preformed. I have never found a new replacement.
When I did replace one I used a longer piece of hose and made a sweeping curve so it did not kink. Others have bebt the metal tube at the frame to make the line curve better.
478
12
Tucson AZ
Well I don't know that it is bad. I'm going to replace my fuel pump because it is hemorrhaging from somewhere so I thought I'd replace that line at the same time. Do you think this is an unnecessary thing to do if there isn't a specific problem with the hose?
Warthog
232
OKC, OK
One issue to look for is if the hose has been rubbing on the crossmember. Many times the right motor mount will fail, allowing the engine to drop on the right side and the hose will start rubbing on the crossmember.
If the hose is okay, just reuse it.
Warthog
232
OKC, OK
Use a jack with a board under the oil pan. Helps raise the engine enough the help remove the pump. Also use some grease to hold the pump rod in place.
cucvrus
10,348
Jonestown Pennsylvania
I think Warthog is telling you to remove the push rod cover plate and clean and replace that gasket while you are in there. Just leave the 2 M6 bolts loose on the bottom of that cover plate until the last 2 to tighten. that helps get the 2-3/8" bolts on the fuel pump lined up and let them loose also until you restart the metal fuel line into the pump. I hope that helps at the risk of being over helpful. Good Luck and be patient. It will be a task if it is your first one.
llong66
kokomo, In
Rusty,
If I was already there, I would just go ahead and replace that small piece of rubber hose just as PM, who knows how longs its been there!
Just my 2cents
Good luck!
Greg
