the proud owner of a MEP-004a.
212sparky
Monroe/ Ohio
This evening I picked up a MEP-004a. it is in good condition, and with some new filters and oil and diesel will be back in running condition. once i find the cable for my camera i will up load my pictures. i do have a few questions, on the side of the injector pump there is a small handle, does it need to be lock wired down? (It is in my pictures) also on the fuel fill tube there is a white calcium like deposit on the inside, has any body ever had this develop?
Thanks,
Rob
swbradley1
Modertator
1,612
Dayton, OH
When you figure out what the white stuff is let me know, it's inside my Deuce fuel tank as well.
I suspect some creeping crud.
212sparky
Monroe/ Ohio
I can use the 15KW at work when we do outages. plus the price was right and when i am out at the farm i can power up the barn all at once instead of doing one load at a time.
212sparky
Monroe/ Ohio
I have a cable stripping machine that pulls 4 KW plus its support equipment. i can always plug in a heater or two that i have :)
PeterD
Jaffrey, NH
also, the landing gear is broken. the crank handle spins and can be pulled out. is this a common problem?
Common? Not sure, but mine was broken. There is a breakdown, and some info on it in the manual (trailer).
You will need a *big* pipe wrench (say 30 inches) to take it apart if you need to get at the guts beyond the top. Once disassembled you will probably find a missing clip for the crank handle, this can be fixed without a full disassembly.
Your stabilizer legs on the back of the trailer are easy to rebuild too... Someone bent the snot out of mine (with a fork lift, I bet) but a couple hours, and some fighting set them right.
Oh, and congrats on being another MEP-004A owner!
gimpyrobb
dumpsterlandingfromorbit!
27,785
748
Cincy Ohio
Should be an M200. Those have roll pins the break and are easily replaced. Just unbolt the 4 bolts, no need for a big pipe wrench. Bring it down if you can figure it out.
PeterD
Jaffrey, NH
If it is just the roll pin, then it is a 'piece of cake.' Mine was more complicated with a part in the lower assembly (hence the need to unscrew the leg from the body) which was 'off'. I can't remember exactly why mine failed, but since repairing, it has been working just fine.
My (M-200) trailer shows some evidence of misuse, maybe even being dropped at some point. Both the landing leg, and the two stabilizer legs were broken. My landing leg mount is very slightly bent too, but I'm going to ignore that minor problem!
gimpyrobb
27,785
748
Cincy Ohio
Kip and I have parted plenty of these out and sold some others. I have parts at the house for the lower assembly if its something other than the roll pin. I did have to take one of the lower assemblys apart and it was NO FUN! I had the right tools and it still sucked, I bet using a pipe wrench was murder.
Nehog, if you decide you want good stabilizer legs let me know and I'll see what we have left.
PeterD
Jaffrey, NH
I think my rebuild was successful, but thanks anyway. One does stick a tiny bit but it works.
The biggest problem was that when it was abused, the bolts that hold the stabilizers on sheered off at the nut end, and the retaining pins bent like pretzels. The pins would not come out until I managed to straighten them (thank goodness for that big six ft steel pick!) and it took a bit of work to remove the bolts, but they eventually came out too... I got new bolts at the hardware store, and drilled them for the cotter pins. Straightened the retaining pins on my anvil.
indy4x4fab
Banned
1,711
41
indy, indiana
I sure hope you are planning on bring that to all the rallies. I would chip in money for the fuel just to use it instead of using my little 5500 watt gen to power my camper trailer. Is that a muilt-fuel 4 cycled-er gen unit, or just strait diesel? Oh and if you need any parts for the m200a1 trailer, doc's got four trailers he scrapped out but kept all the usable spare parts just scrapped the frames.
